Need advise on 3PH for Case SC Tractor
J.T. Hartley
05-03-1999 15:53:29
I have a Case SC Tractor that has 2 lower hydraulic arms. Can this be adapted to accept 3 point implements? I am particularly interested in being able to use a post-hole auger.
Mike
05-03-1999 18:57:41
 Re: Need advise on 3PH for Case SC Tractor in reply to J.T. Hartley, 05-03-1999 15:53:29
Does your tractor have two arms with a hole approximately 1-1.5" in diameter at the ends or do the ends look claw shaped like a half closed fist. if you have the claws you have three point hitch and your auger should fit perfectly. The third point should be under the seat or possibly a plate over the PTO. As for the third arm, if you didn't get one with the tractor, their out there but are kinda pricey. If your tractor is 1951 or newer you should have the claws.
Hope this helps.
