smoke
Ted in Sacramen
08-02-2003 13:21:30
Well I enjoyed a great run in recovering this 1948 VAO from abandoned and stuck. Runs great and starts easy, but has started to smoke at idle, does not smoke at higher rpm. Consider that since I got it running it may have ten hours of putting around, not working under load, and at idle it just started to pump out the white smoke, about thirty seconds to a minute after it idles down. What could have happened did I crack a ring, glaze a cyclinder, I'm guessing I'll have to pull the head, but was hoping that something else might be in the mix, any suggestions. Oil pressure is good (12 at idle 15 at rpm) and I did check the rocker assembly for lubrication when I first started it, no transfer of fluid, water and oil, no exceptional engine noise. It doesn't smoke when it starts, except the rich mix from choke. I'll run a compression test this afternoon and see if there are any indicators, anyone know where I can get a head gasket? I think I may be going inside.
C. Amick
08-04-2003 09:34:50
 Re: smoke in reply to Ted in Sacramento, 08-02-2003 13:21:30
Have you looked in the bottom of the oil pan to see if there is any coolant in it? If nothing is cracked, I figure the piston oil rings are stuck. N A P A Autoparts sells the gaskets.
Ted in Sacramento
08-04-2003 18:47:07
 Re: Re: smoke in reply to C. Amick, 08-04-2003 09:34:50
Here's what I been looking at and I admit I'm no mechanic but I do know some. There is no water in the oil, or oil in the water. I thought that if I had a cracked block I would see air bubbles in the radiator which I don't. I did run a pint of tranny fluid in the oil for about six seven minutes at idle while smoking to see if I could free up whatever is stuck and causing the oiling, no help. Same symptoms doesn't smoke when you start it, doesn't smoke at rpm smokes like crazy at idle. Will probably have to pull the head, not the end of the world, to find out what's wrong. I'm leaning toward the oil return holes in the ring grooves being gunked up but pulling the head won't resolve that. Also it runs and idles perfect which leaves me to believe it's not the head gasket. But then I'm no mechanic.
Ted in Sacramento
08-02-2003 22:34:20
I think it is oil smoke, I did check the radiator and don't see oil yet. I was looking at my service manual and think maybe I could have oil return holes plugged up in the ring grooves, but that is just me trying to figure this out. It doesn't smoke when it is operated at rpm and doesn't smoke until it has run awhile then returned to idle. I'm half tempted to run it a couple minutes with some tranny fluid mixed in the crankcase, but I'm not sure this is a good idea either.
Glen
08-03-2003 11:28:51
 Re: Re: smoke in reply to Ted in Sacramento, 08-02-2003 22:34:20
I'm still thinking blown head gasket or cracked head. It takes a while to warm up letting the crack open. Then at the higher RPM you have enough compresson to keep the water from getting into your cylinder. You might remove one plug wire at a time and see if the smoke quits. This would narrrow it down to the cylinder that is having a problem.
Glen
08-02-2003 20:51:41
You say white smoke. Could this be steam? Check your radiator and see if there is any oil residue on the water or in the neck of the radiator. If there is then I would look for a blown head gasket or a cracked head.
