Manifolds or repair for SC?
G. L. Perry
08-01-2003 02:17:31
Have 41 SC, one peice manifolds. I now see after clean-up of tractor, that the exhauste wasn't touching one port. After removing, can see all the ports were weak. Intake is still good at ports. Is there a weld/buildup/machining trick to do on this, or is it replace only? I see in some catalogs, replacement manifolds, but not for the case SC. Is there new ones? Anyone ever cut off the intake and make an exhaust from tin that works? Kinda like headers are made! Are all the used ones gonna be Junk too?
rustytractor
08-01-2003 18:58:12
 Re: Manifolds or repair for SC? in reply to G. L. Perry, 08-01-2003 02:17:31
Mr. Perry,
I have a good used manifold for an SC if you are interested. I had to by it to get a good air cleaner stack and it is just sitting on my bench now. 65$ plus actual shipping cost. Let me know if you are interested.
Thanks,
Shane
G. L. Perry
08-02-2003 01:05:21
 Re: Re: Manifolds or repair for SC? in reply to rustytractor, 08-01-2003 18:58:12
Shane, I Might be! I have to look localy at one Sunday. Where are you at? I'm going to tractor show Sat and won't be home but I'm at 260-358-8401 or [email protected] to connect or send me your phone, I'll pay the dime! I also need the air stack! Have ANY of the air stack parts extra? Does the manifold have the elbow with the bolt on tabs for air box stack?
Randy
08-01-2003 14:06:24
This may be a silly question but you did make sure that the gasket inserts were inserted into the recess in the ports?
Randy
John H-WI
08-01-2003 09:47:33
Give Don Livingston a call or email him [email protected] he may be able to help you.
george md
08-01-2003 09:47:22
GL ,
JB weld won't stand the heat , brazing is good,
acetylene / cast iron welding is better .It is the
same material as the manifold , easy to weld and
easy to file or machine .If done carefully and
ground smooth you will not see the repair .
george
C. Amick
08-01-2003 08:53:40
No, no one is making reproduction ones yet and used ones are getting hard to find. I would try having it milled or building it up with brass and then having it cut down. I am told that J.B. Weld doesn't work that well on exhaust systems.
John Saeli
08-01-2003 10:23:07
 Re: Re: Manifolds or repair for SC? in reply to C. Amick, 08-01-2003 08:53:40
Hey George & C Amick; For minor "fills" the JB Weld has worked fine, no failures here. It probably would depend on how much the port had to be built out.
Kennyp
08-01-2003 12:55:58
 Re: Re: Re: Manifolds or repair for SC? in reply to John Saeli, 08-01-2003 10:23:07
On the shelf right beside the JB weld I found "thermo steel". Kind of like a dough that you kneed. Says good to 2400 degrees. For mufflers, boilers, and such. I've not used it yet, so take this for what its worth.
george md
08-01-2003 12:54:00
John
Send me an email so I can get your address, there
was a time I lived in your territory.
george
John Saeli
08-01-2003 05:21:51
Hey G. Perry; How much gap do you have? The whole manifold can be milled back to "flush". I file them by hand. If 1 port is really bad, it can be brazed back up, or I have had good luck with JB Weld.. Another possibility is to double gasket the offending port. Hope this helps.
