Do the early Case 930s have live PTO?
Garry
07-30-2003 19:17:06
I have a 1962 regular 930 and a 1963 930 CK. Do they have live PTO? Both have hand clutch and are diesels. I searched archives but could not find answer. thanks for any help
Craig M
07-31-2003 22:58:44
 Re: Do the early Case 930s have live PTO? in reply to Garry, 07-30-2003 19:17:06
Yes, but they have no PTO brake, allowing it to rotate even if disengaged.
Garry
08-02-2003 09:51:46
 Re: Re: Do the early Case 930s have live PTO? in reply to Craig M, 07-31-2003 22:58:44
I had a guy look at the tractor to buy but did not buy because the PTO would not stop spinning. He said he needed a tractor to pull a bailer and need the pto to stop. Is there a way to get it to stop? This pto doesn't stop if you disingage it. Does it need adjustment or rebuild or they all work like that?
Paul f
08-03-2003 07:01:24
 Re: Re: Re: Do the early Case 930s have live PTO? in reply to Garry, 08-02-2003 09:51:46
If the PTO clutch is adjusted properly it will stop spinning when you hook something up to it (or push your foot against it)
If it actually turns over the equipment when the clutch is disengaged you need to loosen the PTO Clutch adjustment or you have a more serious problem with the clutch plates fused together, as was case with my DC. The two kinds of plates and springs that go between them are still available at the dealer.
John Saeli
07-30-2003 19:36:38
Hey Garry; Yes, all 930's have live PTO
