Sticking Clutch Plates
C. Amick
07-30-2003 09:18:34
I was wondering if the fiber clutch lining is any less or more likely to stick to the flywheel than the metalic lined clutch plates? I've also been theorizing as to why they stick. Does the thin layer of oil that's compressed between the clutch plate and fly wheel get sticky?
Klyde
07-30-2003 10:03:38
 Re: Sticking Clutch Plates in reply to C. Amick, 07-30-2003 09:18:34
I have commented on this before. We had this problem for many years and the only "fix" was to drill a 1/16 hole through the rivets. The oil gets in the space between the rivet head and the flywheel and the pressure plate and acts like a little hydraulic cylinder, holdind everything together. I did'nt belive it at first, but, after drilling them out , no more preblems.
