sc case fixed factory wide front
Milan Davig
07-30-2003 08:08:10
Did the sc case ever come with a fixed wide front axle placed immediatley under the front of the engine? The front looks like a S case but the rear wheels are adjustable and the serial tag says sc.
Mike Schotte
07-30-2003 09:40:46
 Re: sc case fixed factory wide front in reply to Milan Davig, 07-30-2003 08:08:10
Yes- that's an SC-4. Here's a picture:
-Schotte
Doug
07-30-2003 14:29:34
 Re: Re: sc case fixed factory wide front in reply to Mike Schotte, 07-30-2003 09:40:46
I thought that an ajustable wide front and a ticycle front were both considered a SC-3 and the SC -4 had a non adjustable , standard front somthing like a S standard only the axel had a arch to it to make the tractor set level, I'm not sure ,but I think they only made the SC-4 about 2 years at the end of production run. Am I wrong on this guys??? Just my 2 cents worth!!! Doug
martin in De.
07-30-2003 18:01:11
 Re: Re: Re: sc case fixed factory wide front in reply to Doug, 07-30-2003 14:29:34
Doug,you are correct the SC4 has a fixed front axle. But I have seen some manuals list the adjustable frontend as an SC4.
