DC clutch
Ken
07-30-2003 04:12:50
Can someone tell me will a pressure plate from a live PTO unit work on older unit? I have a 48 Dc that the clutch doesn't want to work properly,I have a used one from a 52 with live power.that is good wondered if I change the disc and flywheel if it would work.
DKase
07-31-2003 21:24:57
 Re: DC clutch in reply to Ken, 07-30-2003 04:12:50
Pull the inspection cover off the side and look to see if one of the small pins in the throw out bearing linkage are broken or missing. Something like that must be wrong because these wet clutches don't give much trouble. Good Luck
