Where to plumb in oil filter return line???SC
farmer_nk
07-29-2003 21:58:32
I'm trying to install a motor oil filter on an 1944 Case SC. I was wondering where to plumb the return line from the oil filter canister. The inlet is Teed into the oil pressure gauge line. If I drill and tap a hole in the block for the return line, will I lose the ability of the oil pressure gauge to work properly? SC's that had the oil filter option have a flat part on the block where the return line enters, mine doesn't. The casting # on my 44 is 5600A and the SC I looked at had a casting # 5626A, whats the difference if any? thanks
C. Amick
07-30-2003 07:45:41
 Re: Where to plumb in oil filter return line???SC in reply to farmer_nk, 07-29-2003 21:58:32
I have SC's with and without oil filters. I've thought about tapping the block to install a filter on those that don't have them, but I figured the risk of messing something up was greater than the need for a filter.
Klyde
07-30-2003 04:42:01
Why bother?? Tractor has run for 60 years without one, it won't give you any more power, and it WILL decrease the amount of oil available to the parts that need it. Oil is cheep. Change it often.
