question for you pullers
steve
07-29-2003 16:40:06
i have a set of 13.6-38 on my dc that are badly weathered,good tread. i have a set of 14.9-38, carcass is very good, tread is about 10%. i have been told that these are for 13 inch rims, but will work on my 12 inch rims. would this be a good tire to use? i have had trouble with traction, pulling in 4500# (with spoked rims and 12.4-36 tires) and in 5000# plus using the 13.6-38's. thanks for any help.
Jim M
07-29-2003 19:06:49
 Re: question for you pullers in reply to steve, 07-29-2003 16:40:06
Are the front tires staying planted on the ground or is the front end coming up at all? Tires sound OK
steve
07-29-2003 19:47:23
 Re: Re: question for you pullers in reply to Jim M, 07-29-2003 19:06:49
the front end is coming up about 8-12 inches. i have replaced the heavy cast front wheels with some light cut down pressed steel rims.
Jim M
07-31-2003 18:24:22
 Re: Re: Re: question for you pullers in reply to steve, 07-29-2003 19:47:23
Steve I would try moving the hook point a little closer to the center of the rear axle. I pull a DC in 4500 and 5500 also. Our rules in Stock class require me to use the orginal cast rear centers. It was tough to get to 4500. What rear cover are you using over the rear chains. I have a DO cover with no hydralics and pto removed. This allows you to get to the 18" length easily. There is also a cover avliable that has no PTO and has a large Eagle that when painted looks real good. The 14.9s should work OK on the 12" rims but would be better on 13 or 14s. What pistons and head are you using in the motor?
steve
07-31-2003 19:09:58
 Re: Re: Re: Re: question for you pullers in reply to Jim M, 07-31-2003 18:24:22
jim, i removed the drawbar and use a twisted clevis attached to the frame that the drawbar rest on. i still have the original rear plate with the complete pto assembly. where could a rear plate like you described be located? i have 4" alluminum pistons with a high compression head. i have never had any trouble with power. our rules say stock classes have to run low gear or 3.5mph, i don't have the low geared rearend and have never tried 2nd gear?
Jim M
07-31-2003 19:34:11
 Re: Re: Re: Re: Re: question for you pullers in reply to steve, 07-31-2003 19:09:58
Those rear plates are hard to find. Down here in Florida the DOs with no PTO had them. DI would have them and I think any C,CC or CI without PTO would have them. An early DC with no hydralics should have a short cover with a extended PTO housing. They should work also. Check with Don Livingston for a cover at [email protected] or in the AM at 507-433-0073. We made a shorter drawbar support and we have to pull from a drawbar. I use a step up drawbar to get the highest allowed height. They made 2 different 4" pistons low and high compression. I have the low with a 5505A head. I think your front end is coming up too much. Try and keep it only an inch or soo off the ground by going shorter and go as high as they will let you.
steve
07-31-2003 20:07:12
 Re: Re: Re: Re: Re: Re: question for you pullers in reply to Jim M, 07-31-2003 19:34:11
JIM thanks for all the advice, i appreciate it.
