VAC Exhaust Manifold
Frank in Ohio
07-29-2003 15:40:29
I have been searching the local yards for a replacement exhaust manifold for my case VAC (1952 vintage) No luck. This area I guess was not a big Case area. I understand that there was a burn out issue with a lot of the manifolds because they were so thin. Does anyone make a aftermarket replacement?
Thanks a bunch!
theres on on ebay
08-02-2003 17:16:55
 Re: VAC Exhaust Manifold in reply to Frank in Ohio, 07-29-2003 15:40:29
looky over heah on ebay
Frank in Ohio
07-29-2003 20:15:06
Thanks for the info, I'll try both resources. With a bright refurbished carb and new air cleaner I don't have the heart to keep the old manifold. Somebody probably welded up a burn through hole. It looks like they "spit" the weld on. Pretty nasty looking!
Slowpoke
07-29-2003 23:09:05
 Re: Re: VAC Exhaust Manifold in reply to Frank in Ohio, 07-29-2003 20:15:06
A friend had the same problem with a Chevy 6 cyl manifold repair. He had it brazed at a professional shop (supposedly heated in an oven), and I doubt if the cracks were Vd as the brazing material was blobbed 1/8-3/16 thick, and a very poor looking job. $75.
Jim M
07-29-2003 19:10:01
Check with Don Livingston at [email protected] or call him in the AM at 507-433-0073
Pat
07-29-2003 18:22:43
Hi Frank! Try "MYOLDPARTS.COM" that is where I found a good used one. Haven't seen a repo yet
