What seat do I have? SC?
G. L. Perry
07-27-2003 20:02:39
Have an SC with seat with rubber like Oliver had. A fellow I talked to said should be big spring under seat on these. Most looks orig, cept part about the mount over the pto area. It has stops both full up and down compress. Some rubber stops missing on seat bottom where it hits frame. the seat pulls back and angles up on slider, looks like to stand and clear operator. I have stands behind axle, it looks correct. The throttle is mounted on the stand for seat, looks correct. I have parts books on order, so have nothing to compare. Could this still be Case seat, just diff model? I have several pictures I could send to someone to see what I have. Help me out here. The rubber is nice, but too soft and bottoms out. It has adjustments, can't move now, looks like it's adjusted out anyway. Two big adjustment knobs on it.
jal-SD
07-28-2003 06:17:09
 Re: What seat do I have? SC? in reply to G. L. Perry, 07-27-2003 20:02:39
My '54 SC has a "comfort seat" that sounds like its the same as the one you have. It does not have a spring, only the big rubber bushing-its similar to the ones on later model Case tractors. The rubber bushing is available from Min-Kota Repair-38893 County Hwy 14-Ortonville, MN 56278-(320) 839-3940. They are spendy-$125 plus bushings & shipping. You will want to send your old one in to make sure they match it, as there are several different sizes. Also have to grind off rivets & rivet in the new one. Make sure you mark the way the old one is riveted in as you can get it wrong-(don't ask how I know this) & it won't work right. If you want more info, post back & I'll get my book & get details. (My $0.02 worth. jal-SD)
