580ck 'b' brakes
joe francano
07-27-2003 18:05:43
Hello,
Have a 73 580ck 'b' model tractor and backhoe. I am doing a brake job on it. The brakes are a disc and drum like I have never seen before. There is a PTO for the brakes. The brakes drum/disc assembly slides on the PTO in order to stop. The brakes that I removed were trash, so I am replacing everything.
I am curious if I should apply some type of lube to the spline on the PTO that the brake disc/drum slides on? Any help is appresiated.
Marc
07-27-2003 18:48:42
 Re: 580ck 'b' brakes in reply to joe francano, 07-27-2003 18:05:43
Joe,
The splined shaft does not require lany lube. It is a dry brake system. Check the link below for part numbers and about half way down the page you can view an illustration of the brake assemblies and then a little farther down the page you can view a illustration of the transaxle so that you may get a better understanding how the brakes work. If you need any thing else let me know.
Hope this helps, Marc
