Case 311 front axle Wanted
Dick (IL)
07-27-2003 15:30:20
A neighbor loaned out his Case 311 w/loader. Borrower returned it with the rh front spindle/wheel broken off. The 311 is equipted with a two wheel tricycle front end. The short axle fits on the vertical steering shaft in a tapered hole and is secured with a key and nut. Owner says the serial number pegs it as a '58 model. Can anyone provide part number and interchange possibilties? Or a source for a used one? Don't say T&C in Des Moines, IA - owner has already been on the phone with them, the guy he talked to didn't know up from down about older Case tracors.
Any help greatly appreciated.
Kennyp
07-27-2003 20:26:52
 Re: Case 311 front axle Wanted in reply to Dick (IL), 07-27-2003 15:30:20
You might try Bridgeport Neb. Don't have his 800 number, but a search for parts, tractor, bridgport etc might find it. Anybody got it? He's a pretty nice guy. Found me an exhust manifold for 300. Acres and acres of machinery.
Joe (Wa)
07-27-2003 19:50:34
Hornizontal shaft: "p/n G10812 spindle - steering, daul wheel, 3/4" hex hd slotted nut, NF with plain washer, 1/8" x 1-1/4" cotter pin".
Vertical shaft: p/n G10850 shaft -steering spindle, #G woodruff key".
Fits GP tractors 301, 311, 301b, 311b, 411b and probably others.
Dick (IL)
07-27-2003 22:22:43
 Re: Re: Case 311 front axle Wanted in reply to Joe (Wa), 07-27-2003 19:50:34
Thanks Joe
