730 diesel fuel problems
bob
07-27-2003 14:36:37
I have a question about this tracor. Its seems if you let it set a day or 2 it will bleed fuel out of the injection pump and is very hard to start. It will turn over and fire on 1 or 2 cylinders and then finally pick them all up. Runs great when gets bleed out. It acts just like other case's when they are first strated after being ran dry. Any ideas check valve stuck somewhere? Have not had the time yet to read the case manual i have yet. Just looking for other ideas. Thanks
chad
08-21-2003 15:44:52
 Re: 730 diesel fuel problems in reply to bob, 07-27-2003 14:36:37
hey bob.....1 thing ya wanna look for is to check all ur check valves in ur pump, replace the brass washers, replace the o-rigs, and check ur fuel line to to tank..... good luck
