dc carb troubles
Dave True
07-26-2003 18:38:52
Hi i have a Dc with a zenith carb on it i have problems with it runing it will start but it dies within a few seconds. i went back in the archives to find out about it but i did not see anything that would help. i have both seting screws on top and bottom set about 1 and three quaters of a turn out each no luckam i doing something wrong any help would be appreciated thanks and have a good week Dave.
G. L. Perry
07-26-2003 20:42:23
 Re: dc carb troubles in reply to Dave True, 07-26-2003 18:38:52
I helped a fellow drag home a DC. He got running, but had trouble with keeping it going. He found the carb bowl vent was plugged. First he drilled a hole in top of carb and it ran fine. Next, he pulled apart and cleaned/blasted it, drilled out plugs and ran wire into vent holes. After drilling them clean, he put in a set screw to re-plug the hole from outside where it should be closed. He had to tap that hole to use screw. Might look into that for yours!
Larry
07-26-2003 20:26:47
You have the carb set close enough. Sounds to me like you have dirt in the gas lines somewhere between the tank and carb. If that checks out check the float valve in the carb.
Paul f
07-27-2003 08:32:01
 Re: Re: dc carb troubles in reply to Larry, 07-26-2003 20:26:47
I agree with larry if it starts and then stalls it is probably starving. (Unless of course it is blowing back smoke and stumbling before it dies). The sediment bowls are not terribly efficient at removing crud from gas. Get a clear fuel filter at the auto parts store and put it in the line..will also let you confirm you are getting gas to carb. If you are then mostly likely the needle valve is stuck or float adjustment is way off.
