Case C Identification help
frank
07-26-2003 17:53:10
I bought a Case ? C ? serial # C308962 engine # cast to the block is B4848A and on the Dif. housing is # 2143 Can anyone help me idenify this baby. It came from a Vineyard in Fresno Ca.
She has a starter, and the generator is in between the mag. The distance between the fenders is 24 inches on the inside and each fender is abour 2" from the gas tank. I have posted a picture in the tractor photos. Also looking for any manuals on this baby.
Brian in Ohio
07-26-2003 19:05:44
 Re: Case C Identification help in reply to frank, 07-26-2003 17:53:10
Based on your picture, I'm interested in where the serial number is located on the tractor? Because the tractor in your photo is not a "C", that is a "D". A "C" did not come with the hood and grill that yours has. However, the serial number that you put in your post would make the tractor a 1936, and the "D" was not produced until 1939. So, either someone has used "C" parts to put a "D" together, or vice versa.
Call that my $.02 worth...
frank
07-27-2003 14:39:30
 Re: Re: Case C Identification help in reply to Brian in Ohio, 07-26-2003 19:05:44
Brain, The serial # was taken off of the tool box that was mounted under the tractor seat just about the hitch. As you said who knows who put what with what. The battery tray was on the left side looking forward above the rear axle.
Brian in Ohio
07-27-2003 17:55:06
 Re: Re: Re: Case C Identification help in reply to frank, 07-27-2003 14:39:30
Then, I would say that isn't the original toolbox. Check on the engine block for a stamped serial number. Should be a 7 digit number starting with 4 or 5. But, that tractor is definately a "D" and not a "C".
frank
07-28-2003 16:13:31
 Re: Re: Re: Re: Case C Identification help in reply to Brian in Ohio, 07-27-2003 17:55:06
Thanks Brian in Ohio
Found the number on the block D4406864
so I guess she was made in the 40s.
And yes the more I look the more I see it is a "D"
thanks frank
Brian in Ohio
07-28-2003 16:46:15
 Re: Re: Re: Re: Re: Case C Identification help in reply to frank, 07-28-2003 16:13:31
Based on the serial number, your "D" is a 1940. You didn't mention, does it run?
Frank
07-29-2003 15:17:44
 Re: Re: Re: Re: Re: Re: Case C Identification hel in reply to Brian in Ohio, 07-28-2003 16:46:15
Kinda thought so having trouble with the mag. My other cases have Dist. learning how to check it out. When we pulled it to start it fired but would not stay running. She is my 5 year project after my Vac gets done.
thanks frank
case poor in pa
07-28-2003 16:06:37
wellll now i haint ever seen no C with a beterry or a starter exceptin the crank stickin out the front..coursen lots of stuff i haint seed yet.. egads haff kafff harumupff
DC tom graverson
08-02-2003 13:47:07
 Re: Re: Re: Re: Re: Case C Identification help in reply to case poor in pa, 07-28-2003 16:06:37
sounds lilke a DV to me, with gen and mag set up has to be 39 or 40
DV's were narrower than D's
