dc mag has fire again with help
rman
07-25-2003 19:51:24
we had post several times for help to find or repair mag for dc we bought. some said put a/c dist or h farmall dist if could not find parts. not having much luck finding parts or another mag .we fixed it. here is what we done removed mag and removed top plate to access coil removed dist cap to acess points removed old bad coil to make room for condensor and wiring so we could use mag as 12 volt dist mounted 12 volt external coil ran wire from battery to switch so when turn on switch voltage to coil. cleaned points and reinstalled dist cap. hide 12 volt coil so could not see it ran coil wire inside mag.used ballist resister so would not burn point turned engine over till compresson on #1 reinstalled mag this tractor was barn fresh and had not ran in 15 yrs. put in gas and trned engine started. blew looked like old nest out exhaust and pulled all old barn dust threw radiator. there is just something to be said when a old tractor fires up after setting all that time. this is way we fixed mag and real cheap i know this is long but just want to share and by the way this is are first case have 20 john deeres and several other makes. one question for you guys engine sounds real good did notice crank does have excessive end play is this a easy fix or dont worry about it.thanks Mike
