antifreeze in oil
steve
07-25-2003 17:29:08
i am getting antifreeze in the oil in my 1950 dc case, i have taken the head off and had it checked by the local case/ih mechanic, can not see any visible cracks, i put the head back on with a new head gasket, still leaking? even with the head off still got antifreeze in oil, so i assumed it must be coming from o ring below the sleeve? i have tried 4 different kinds of stop leak, bars (liquid,granular)conklin-dike and seal-up, none worked. what can i expect to find once i get in the engine. thanks
Tom
07-27-2003 06:31:38
 Re: antifreeze in oil in reply to steve, 07-25-2003 17:29:08
Steve, after you fix the leak, you should pull the radiator and take to professional shop. Have a rod-out done on it. After the four applications of junk leak sealer, you have probably ruined the flow on the radiator.
Larry
07-26-2003 16:49:48
You probably have an o-ring leaking on a sleeve. You will have to pull the sleeves, clean up the grooves anf sleeves, and replace the o-rings. I made my own o-rings from 3/8" o-ring material glued together and they worked fine.
steve
07-26-2003 21:46:05
 Re: Re: antifreeze in oil in reply to Larry, 07-26-2003 16:49:48
i take this dc to a few tractor pulls a year, and even though power hasn't been a problem (using 12-4-36 tires) i have been thinking about putting in bigger pistons, though i wasn't planning on it in the near future, but being i have to take the pistons and sleeves out any way, maybe this would be a good time to do it. any ideas what something like this would cost and where a set could be located? thanks for info.
Craig
08-22-2003 13:15:18
 Re: Re: Re: antifreeze in oil in reply to steve, 07-26-2003 21:46:05
I had the same problem with my '53 DC. I installed new 4" pistons, sleeves, o rings, piston rings, & good used rods. I got everything from Case IH except rods. the rods came from Don L. You could expect to spend between $1500-$2000 depending on how far you go with it.
Mike from Canada
07-25-2003 19:16:19
i know that when Case made VACs they put a lead plug caled a "fuse" in the head between the valve train and the water jacket. when the cooling system over heated, the fuse would melt. Case called this a safety feature. i call it a self destruct feature. the only safety that it could assure was that Case could sell farmers more engines when they over heated.
remove the rocker cover and check to see if you have a hole near the front of the head on the top where antifreeze leaks out. you may have "blown a fuse".
hope this helps!
mike
