case eagle problems
wes
07-25-2003 00:13:37
i have a '47 vai that i added an eagle hitch to. it's allways worked great.now it won't lower by itself.(no implement attached)it will lift by itself as soon as tractor is started.while running i can push it down with force in release mode.as soon as tractor stops,arms go down easily by themselves.when in neutral position,it slowly looses highth position.i was using a heavy homade implement to clear brush and hooked a stump while in raise mode.thats the only wierd thing i did with it.i have taken apart everything and it looks fine to me altough i,m not the sharpest tool in the shed.i would sure apprieciate any and all advice as i have taken the control box apart ,checked hoses,etc.only thing i haven't opened up yet is the ram itself and that is next,i fear.
thanks,again
wes
Joe (Wa)
07-25-2003 18:42:19
 Re: case eagle problems in reply to wes, 07-25-2003 00:13:37
Problems: The hitch lifts when you start the engine because the lift valve is not returning fully to neutral. When you put the lever to the lower position the pump is still admitting some oil pressure to the piston and the release valve can not handle the volume. The hitch drops slowly under load when the release valve leaks, lift check valve leaks and/or there is leakage pass the piston.
Assume you have checked the return oil filter, T tube breather and pulled the leakdown tube off the cylinder to check for piston leakage.
You probably know the following but maybe something here will jog your noggin.
Pump discharge is in communication with the lift passage in the block at all times. The lift valve only controls the by-pass return to the sump and thus the oil pressure available to lift the hitch. When the lever is in the raise position, the lift valve closes off the by-pass allowing the pump pressure to open the spring loaded lift check valve admitting pressure to the top of the piston. When the lever is in neutral the lift valve spring returns it to neutral and pump oil output to the sump. The draft arms are held in the up position by the hydraulic lock of the lift check valve and the release valve. When the lever is in the lower position the release valve opens to dump the piston oil into the by-pass passage and draft arms drop.
Good luck, Joe
goodoldboy
07-25-2003 01:02:24
my 49 vac has to have a spring on it to return it to the lower'ed position. the eagle hitch has a place on it for a spring, if you look in the store bought t&c book's it will show this spring. you can buy this spring at any tractor supply or door place! let me know if i can help with this tractor in the future .
