SC fuel drain size
Eric Rylander
07-24-2003 18:28:00
I am getting my tractor parts together for my visit to see it/my family.
The sediment bowl broke and I rigged one from a Farmall base with a stick as the thumbscrew and a gasket cut from innertube.
ANyway, my dad complained about it leaking gas all over his shed.
I plan to get a simple pipe nipple, a ball valve, and then an inline filter to replace it.
Is the thread in the tank base 1/8, 1/4 or 3/8" pipe?
Eric
C. Amick
07-25-2003 09:20:04
 Re: SC fuel drain size in reply to Eric Rylander, 07-24-2003 18:28:00
NAPA also carries a plastic ball valve that you can insert in your fuel line for fuel shut off. I would still get the sediment bowl. It will capture the big particles. The plastic valve is much more convienient for fuel shut off. You only have to give it a quarter turn. I also buy NAPA's clear plastic in line fuel filters for my SC.
RandyD
07-24-2003 19:26:37
Here is a picture of the one I got from NAPA for my SC. A Standard item.
Randy
Eric Rylander
07-25-2003 03:01:12
 Re: Re: SC fuel drain size in reply to RandyD, 07-24-2003 19:26:37
WOW! Can you get me a NAPA part # so I can order it??
Eric
