Schebler Marvel Carburator
don
07-24-2003 09:33:26
Have an old Case backhoe/loader with Schebler-Marvel carb. Runs fine for first thirty minutes or so then begins to lunge and stall. Acts like it's starved for gas.Can manouver at low speed if I choke it. Any tips on tuning this carb? I'm definately not familiar with the Schebler carb.
C. Amick
07-25-2003 09:28:38
 Re: Schebler Marvel Carburator in reply to don, 07-24-2003 09:33:26
Are you sure that it's not dirt in the gas tank getting over the gas tank outlet when you have moved the tractor and sloshed the gas around?
Joe (Wa)
07-25-2003 14:40:41
 Re: Re: Schebler Marvel Carburator in reply to C. Amick, 07-25-2003 09:28:38
That's is probably the best advice, check for loose debris in the gas tank. While you're at it, check the cap vent clear & sediment bowl strainer clean. Pull fuel line off at carb fitting, should have full flow in tube, if restricted, blow back thru the tube into the tank, if clear now it's time to think about tank cleaning. Carb overhaul is next if necessary. Good luck, Joe
