Sleeve Assemblies for a 400 Case Diesal
John
07-24-2003 08:59:27
I am having trouble finding sleeve assemblies for a 251 diesal but 267 sleeve assemblies are plentiful. Wondering if anyone has machined their blocks for the larger sleeves and what the results were.Also wanting to know where to find a used air cleaner assembly for a 400. Any info on either of these would be much appreciated!
Larry
07-24-2003 15:35:53
 Re: Sleeve Assemblies for a 400 Case Diesal in reply to John, 07-24-2003 08:59:27
If you do have to go through the trouble of boring the block for a bigger sleeve set. Why not get a set for a 830. Someone had done that to one of my 400's and now it has 301cid.
Jim Handke
07-24-2003 13:54:14
Contact elmer or bryan at [email protected]. They part out case tractors and should have an air cleaner for you.
Dale In Tx
07-24-2003 09:30:36
hI John I put the 4-1/8 pistons and sleves in my 411 when it was new didn't do anything to the block, It is a '56, they came out in '57 with the "super" think all the blocks were the same till ,58 and the 700 and 800 block had the wider flange. If not M&W made a set. LOL Dale in Tx.
