case-o-matic,junk?
JOHN
07-23-2003 18:48:36
I was just wondering what the real advantage is of having case o matic drive over regular gear drive. i've ran an 830d with this drive and it seems pointless and a real "terd" in the field. how reliable is it and how does it work?? thanks for any info..
Glen
07-24-2003 06:11:57
 Re: case-o-matic,junk? in reply to JOHN, 07-23-2003 18:48:36
The C O M Is a very good transmission if taken care of. The main thing is to keep the fluid clean and at the right level, keep the filter changed and watch your fluid temp. If you do this it will give you many years of trouble free service. Don't let them get hot and warp the clutch disc's. Keeping them in C O M for long periods of time on a hard pull will cause them to over heat.
Dennis
07-23-2003 21:15:14
After you get going you should be locking the converter for a direct drive for what ever gear you are in.The whole Idea of it is that when you bog dowm you move the lever and put it in to the converter and keep going you don't have to stop and shift to a lower gear. I have a 611b and It is alot better than a standard I use to have.
SHeiserman
07-23-2003 19:58:58
Define 'turd'. Never worked a c-o-m hard, but I hear a properly weighted 830 c-o-m will monkeystomp an IH 706 or JD 830. It's a real pain in the (deleted explicitive) to get people to talk about c-o-m, so maybe calling it a turd will work.
Hey JOHN
07-24-2003 18:49:25
 Re: Re: case-o-matic,junk? in reply to SHeiserman, 07-23-2003 19:58:58
John, I wasn't trying to be a smart alek with that response. Why do you think it's a turd? Took me a little bit to get used to mine. Just have to make sure you're at idle when you shift and take off (that was my biggest problem with it). All I've ever done with mine is push snow around, and it works great for that.Anyways, good luck with yours.
K-Mo
07-23-2003 19:21:58
In simple terms, it's my understanding that the Case-O-Matic "slipage" keeps the engine at max horsepower RPM and therefore maximizes work efficiency. Supposedly this is also true for PTO driven equipment. In the case of a silage cutter, if an overload begins to pulldown the engine RPM, the Case-O-Matic will reduce ground speed and keep max power on the PTO.
True or not this is the explaination I have received.
K-Mo
John Saeli
07-24-2003 05:26:13
 Re: Re: case-o-matic,junk? in reply to K-Mo, 07-23-2003 19:21:58
Hey K-Mo; You pretty much summed up the C-O-M to a TEE. It gave you the best of both, Converter or fluid drive for the hard pull, then at your choosing, Direct Drive for normal going.
