Help with 530 engine swap
Scott
07-23-2003 18:24:09
I am putting a combine engine in my early 530 backhoe. I pulled the G159 and am ready to install the 201 (Gas 188?) but need an oil pan. I think a diesel 188 pan will work. Is this right? Also is there a different pan on the industrials? The backhoe needs a pan that is flat for quite a distance in the back for the wishbone to fit under. Any help would be appreciated!
Gary J
07-26-2003 17:24:07
 Re: Help with 530 engine swap in reply to Scott, 07-23-2003 18:24:09
Scott, what are you doing with the old engine? Is ts scaped or of some value? I have a 580CK with the 159 and may want to rebuild the engine and having one out to rebuild before pulling the tractor apart would speed the tear down tur-a-round,
Thanks, Gary
Scott
07-27-2003 06:18:20
 Re: Re: Help with 530 engine swap in reply to Gary J, 07-26-2003 17:24:07
I'll sell the complete engine. There is a hole in the block the size of your fist from a thrown rod on #4 cylinder. So you will need a block, and probably a crank. There is a guy in upstate NY with a block and turned crank for $300. What do you think is fair for the scrap 159?
DON L
07-25-2003 06:32:04
i have one.
Scott
07-25-2003 14:23:58
 Re: Re: Help with 530 engine swap in reply to DON L, 07-25-2003 06:32:04
Thanks Don, I would like the pan. I understand the Gas 188 (201) is a little longer. Other than the hood, steering linkage and wishbone or whatever you call the front axle attachment at the rear of the pan, am I missing anything that may need to be changed?
its longer you know
07-24-2003 04:46:17
188's and 201's are longer than a 159. mounts will be off and the hood too short.
