help with case tractors
mike
07-23-2003 16:01:28
I have located two case tractors, one says 700 on hood and data tag says 712-b with serial number 8144072 the other says 830 on the hood and the tag says 840 with a serial number of 8211536 how do I found out info on these tractors about cid and yr mfg and hp and vlaue? they are currently parked on a lot like they have been abandoned. Please respond to e-mail as I don't know if I can find this location again.( not very computer literate.) both tractors run on Lp gas. one has three point with eagle hitch the other only has drawbar. both have aux hyd.
Colleen
09-16-2003 10:26:09
 Re: help with case tractors in reply to mike, 07-23-2003 16:01:28
We, too, have a 712B model that is not running. I would be interested in finding parts for it or finding out what would work as an interchange....
anyone out there with info???
Thx!
mike
07-25-2003 12:27:41
just talked to a family member and the two case tractors belong to his brother and the estate. seems to think one has a cracked block and doesn't remember much about them. how hard and expensive is it to repair/replace block and what will interchange?
MIKE
07-24-2003 11:19:50
THANKS FOR THE COMEBACK, WHAT WOULD BE A FAIR PRICE FOR THESE TRACTORS, DON'T KNOW IF THEY RUN OR NOT. JUST FOUND OUT WHO THE OWNER IS AND GETTING READY TO CALL AND SEE IF THEY ARE FOR SALE. WANT TO KNOW WHAT RANGE IS FAIR. LOOKS ALL SHEET METAL ON THE 830 IS THERE BUT THE 700 IS MISSING THE HOOD, AND FRONT GRILL. HAVE A LOCAL SALVAGE YARD WITH PARTS AVAILABLE.
Joe Peeper
07-25-2003 08:09:06
 Re: Re: help with case tractors in reply to MIKE, 07-24-2003 11:19:50
There were 219 tractors made according to my books that were the 712B model. This tractor from a collector point of view is more rare than an 830 LP. The value depends on condition and the availability of parts to replace the missing pieces. It is worth from $1000.00 up to $4000.00, depending on condition. The 830LP is worth about the same also depending on condition. I hope this helps you decide on the price you are willing to pay for the tractors.
Kirk
07-24-2003 21:55:06
I am not an expert on value but propane is not worth as much as a diesel. If the 830 will run and the tires are OK, it should be worth $1000 or more. I do not know as much about the 700. Maybe someone else will know more.
mike
07-25-2003 06:20:40
 Re: Re: Re: help with case tractors in reply to Kirk, 07-24-2003 21:55:06
thanks, that give me an idea if he says make an offer.
Kirk
07-23-2003 22:26:37
I have a 830 case on LP gas. Yours is a 1963 model. I think it has about 65 to 70 HP. Mine had been painted, new tires,good engine & eagle claw 3 point hitch. I paid $3500 for it. That might have been a little high for LP gas. They have 284 cubic inches. The 700 is about 1959 model. That's all i know.
mike
07-25-2003 12:30:07
 Re: Re: help with case tractors in reply to Kirk, 07-23-2003 22:26:37
one tractor is suspected to have a cracked block, how hard/expensive is it to repair/replace and what is the availability of another block? will something interchange?
