Bench testing a Magneto
Paul f
07-23-2003 10:14:32
I have a 4JMA magneto that I have cleaned up and adjusted points. (Thanks to L. Lamp's posting I got the rotor off correctly and reinstalled with the marks aligned. Is there any way to bench test this? I tried clamping it in a vice hooked a spark plug to #1 and grounded the plug to the vice then turned the mag over by hand. It snaps well but I didn't see any spark. Is this a valid means of testing??? Are there any continuity test that I should run???
Thanks paul f
Mike Schotte
07-23-2003 12:46:18
 Re: Bench testing a Magneto in reply to Paul f, 07-23-2003 10:14:32
Hi Paul,
Something weird that I learned about the Case 4JMA magnetos that's different from other magnetos I've worked on- you need to have a wire hooked to all 4 connectors and three of them grounded at a time when you are testing the mag.
I was trying to set the mag to #1 cylinder- and I kept getting a spark out of the #1 lead... 3 out of 4 turns of the impulse.
Robert explained how since the little mags didn't have a safety gap in them to discharge the built up voltage safely, the juice from the other brushes was leaking across and coming out the lead I was testing. Needless to say- I was confused at the time.
I'm sure Robert and Earl Seamands can give you more bench testing info than I can- but I've included a link to one of Robert's previous posts that is helpful.
-Schotte
Dr Cy Kosis
07-23-2003 18:09:54
 Re: Re: Bench testing a Magneto in reply to Mike Schotte, 07-23-2003 12:46:18
Mike,
When the mag on the C failed at Dublin recently, during testing it was doing much the same thing as you describe. Upon disassembly I found it had a carbon track around the rotor plate causing it to try to fire multiple holes at once resulting in a spark that was too week to fire any cylinder. I cleaned the carbon track, reassembled and had individual hot sparks again.
