Was there a part for what I need (Case V) ???
Alberta Mike
07-20-2003 18:54:58
I have a Case model V and am currently redoing the tractor. I could probably make the parts I need but am wondering if the following were (are) available for my model V tractor?
1. A cast blank-off cover for the PTO on the rear housing cover (I don't have the PTO).
2. A cast blank-off cover for the right side belt pulley opening (the belt pulley assembly I have is pretty much toast).
Maybe somebody with an original parts manual could check to see if such items were available.
Mike from Canada
07-21-2003 06:56:47
 Re: Was there a part for what I need (Case V) ??? in reply to Alberta Mike, 07-20-2003 18:54:58
the VAC uses the same plate for the belt pulley (part # VT-41) if that helps any. one of these days im gonna rebuild the pulley i have and ill give you the plate but im not sure when the motivation will come for me to do it.
ill keep you in mind
mike
TomRailsback
07-20-2003 21:49:34
I need to locate my V parts book, but I am sure there was at least a cover for the belt pulley
hole. Neitherof my VC's has a pulley, but as I recall, the covers were homemade out of 3/8 inch steel plate. I think I checked with CASE and the part is "No Longer Available." I'm down at Great Falls so we might be able to work out a deal.
