DB990 electrics - saga continues (Elmer pls read)
Ritchie Leslie
07-20-2003 18:24:47
Problem: Ignition and Hydraulic filter lights stay on at any engine rpm. Oil light and other electrics OK.
Elmer - I replaced the diode assembly with the part you sent me. No difference! Think it could be the voltage regulator? That seems to be the other common point. I've checked the wiring - no obvious breakages or short circuits.
Elmer
07-22-2003 19:23:49
 Re: DB990 electrics - saga continues (Elmer pls re in reply to Ritchie Leslie, 07-20-2003 18:24:47
Did you put a volt meter on the battery to see what the charge system is doing. If you want to phone me again that is fine by me.
