530CK front axle spindle
GARY B.
07-20-2003 13:47:39
Hi. I want to remove the spindle at the end of the axle beam to service the bearings. There's no reference to it in my service manual. I removed the castle nut on top and am not sure if the control arm is taken off with a puller first or if the spindle shaft can be pounded down and out the bottom of the housing. Any help is appreciated.
Marc
07-20-2003 19:47:07
 Re: 530CK front axle spindle in reply to GARY B., 07-20-2003 13:47:39
Gary,
There is a needle bearing and thrust bearing. If the axle end won't hold a bearing it is also replaceable. Follow the link to a parts illustration.
Marc
GARY B.
07-20-2003 20:54:26
 Re: Re: 530CK front axle spindle in reply to Marc, 07-20-2003 19:47:07
Thank you very much Marc. I'll see how everything looks tomorrow.
John Saeli
07-20-2003 16:02:18
Hey Gary; I've always turned the nut upside down and ran it down flush with the top of the threads and pounded the spindle down. Sometimes heat was required. If that axle is like the Ag. tractors, there are no bearings in there. Hope this helps.
GARY B.
07-20-2003 16:20:00
 Re: Re: 530CK front axle spindle in reply to John Saeli, 07-20-2003 16:02:18
If no bearings then bushings? I'll heat it up and try your suggestion. Thanks John
