dc mag wont fire
rman
07-19-2003 19:35:24
we just bought dc case no fire to plugs removed cap and mag cover goil looks pretty rough does any one have a good mag for this or where can we get parts thanks in advance mike
L.Lamp
07-21-2003 18:16:22
 Re: dc mag wont fire in reply to rman, 07-19-2003 19:35:24
You have to be careful with the rotors on all the Case mags. They don't just pull out. You have to take the screw out where the rotor appears to fit into the point backing plate. If you don't you will pull the disc off of the shaft, I know. Also, when putting the rotor back in, there are timing marks on the small and large gear. They MUST be alligned properly. The little gear will have a center punch dot and the big fiber gear will have a couple of teeth shaved off on the back side toward the coil. Also clean the carbon off of the disk where the spark plug terminals make contact with the disc
caseman-d
07-20-2003 09:46:53
Several post back there was someone that had NOS case mag coils for sale. Case mags parts are kinda a breed of there own. You can get other mags to fit without out much problems.
casema
John Saeli
07-20-2003 10:03:23
 Re: Re: dc mag wont fire in reply to caseman-d, 07-20-2003 09:46:53
Hey caseman & rman; I have NOS coils for the 41 mag. They had the 1 piece center body as opposed to the mag with the removable plastic top cover. But, don't give up on that mag. Double check the gap on those points, take apart & clean every wire connec tion, and as was suggested, discinnect the kill wire. I've seen the kill wire going to the dash have a bare spot in it grounding out the mag. I can get rebuilt CASE mags through my supplier, but they are pricey. Most of the mag problems I've seen are caused by something simple. Hope this helps. Don't scrap it.
caseman-d
07-19-2003 20:29:11
check the points, make sure they aren't tusted up, file them shiny then try it.
caseman-
rman
07-20-2003 05:24:27
 Re: Re: dc mag wont fire in reply to caseman-d, 07-19-2003 20:29:11
tryed filing points still no fire need mag parts or will any other dist fit and what kind of dist modifcations will we have to do thanks mike
martin in De.
07-20-2003 07:51:57
 Re: Re: Re: dc mag wont fire in reply to rman, 07-20-2003 05:24:27
you may want to disconnet the kill wire from the mag,if you have not done so yet,some of the kill switchs you pull out to stop the engine some you push in. just a thought
rman
07-20-2003 14:17:31
 Re: Re: Re: Re: dc mag wont fire in reply to martin in De., 07-20-2003 07:51:57
thanks everyone for help this is our first case tractor not sure what year dc it is mag has four screws on cap and four screws on top cover that covers coil removed mag from engine and remove cover cap screws was going to clean points tryed to easy to remove rotor and it fell apart looks like lots of moisture has been in mag this tractor has been setting inside for 12 yrs how does coil come off mag can you still get parts have rebuilt other mags with good results but this is first case mag. thanks for all help lets get this old work horse running again.does any one have break down of mag .
John Saeli
07-20-2003 15:59:17
 Re: Re: Re: Re: Re: dc mag wont fire in reply to rman, 07-20-2003 14:17:31
Hey rman; You have the 4JMA mag, not the 41. My coil will not work. Special tools were used to change coils. Your coil may be all rite though. Put the tractor serial # on the board and we will tell you what year tractor you have.
rman
07-20-2003 18:10:50
 Re: Re: Re: Re: Re: Re: dc mag wont fire in reply to John Saeli, 07-20-2003 15:59:17
thanks john for repley i will get serial #monday and will post coil looks kinda rough any way of checking i broke rotor getting off where can i by new one thanks again Mike
Paul f
07-20-2003 18:02:48
John: Are the 41 and 4JMA Magnetos interchangeable on a DC???
John Saeli
07-20-2003 18:29:09
 Re: Re: Re: Re: Re: Re: Re: dc mag wont fire in reply to Paul f, 07-20-2003 18:02:48
Hey Men:: I don't know where to get mag parts. The 41 & 4JMA are interchangeable.
rman
07-20-2003 18:34:55
 Re: Re: Re: Re: Re: Re: Re: Re: dc mag wont fire in reply to John Saeli, 07-20-2003 18:29:09
does anyone have a dist we can buy. dont care what kind of dist just want to here old girl run thanks for responce you guys are great mike from Ill.
jal-SD
07-21-2003 06:56:22
 Re: Re: Re: Re: Re: Re: Re: Re: Re: dc mag wont fi in reply to rman, 07-20-2003 18:34:55
IH or Delco distributors will bolt right up. We've got a couple of DC's & SC's w/the right-angle Delco on them. They work fine, but I think you have to re-wire the tractors. If I remember right, they run in the opposite direction. We got our last one off of an AC, right-angle Delco's were common on AC tractors. If you have an oil filter, the right-angle ones work better, you have more room. (My $0.02 worth. jal-SD)
