580C hard starting
Don
07-19-2003 12:36:20
My 580C diesel engine starts hard even when warm. Now with summer here and it sets all night it needs a small shot of starting fluid to get it to start in the morning. Could the timing be off or just getting old or what? Any suggestions?
GARY B.
07-19-2003 17:12:24
 Re: 580C hard starting in reply to Don, 07-19-2003 12:36:20
Hi Don. My 530CK was acting the same way. Changed the filters and made sure there was no fuel leaking at any of the connections. I checked the crankcase oil and found it was contaminated with fuel. I replaced the umbrella seals in the injection pump and problem solved. Something to consider before getting too carried away. You might try checking the air filter too.
JimKS
07-20-2003 05:43:55
 Re: Re: 580C hard starting in reply to GARY B., 07-19-2003 17:12:24
Yeah, check the basics first, but if that all checks out, then you're probably looking at either an injection pump, or low compression. I'd say that timing isn't likely an issue unless the injection pump bolts have come loose at some point.
Don
08-09-2003 04:02:03
 Re: Re: Re: 580C hard starting in reply to JimKS, 07-20-2003 05:43:55
I replaced the air filter and battery. Starts right up and runs like a new machine, almost.
Thanks.
