Case 6v wring system
Kevin Racicot
07-18-2003 04:46:17
I have a Case V tractor and I wired it properly (according to diagram) yet I don't get any voltage at the coil. Could a faulty regulator have anything to do with this?
I would appreciate any help I can get.
Alberta Mike
07-19-2003 05:36:57
 Re: Case 6v wring system in reply to Kevin Racicot, 07-18-2003 04:46:17
Forgot to ask you, do you have a photo of your tractor that you could post here on the forum, or maybe contact me directly by email (I've erased the "hide" link on my name here), I'd like to have a look at what you have there. I'm in the middle of a restoration on my model V.
Alberta Mike
07-18-2003 20:53:48
Where is the wire that goes to your ignition switch coming from in your wiring setup? Your battery should have a wire lead (either directly from the battery or from the big starter button which is getting it's juice from the battery) that links up with the + ammeter terminal I think. Then one of the wires from the - ammeter terminal should supply power to your ignition switch. Is your ammeter working (does it show discharge when the tractor is cranked over)?
Kevin Racicot
07-18-2003 15:47:29
No I'm not getting any voltage to the ignition switch.
C. Amick
07-18-2003 11:37:33
Do you have power to the ignition switch?
