Case 444 Mower drive
John
07-17-2003 07:18:29
When I push the lever forward to engage the mower blades, the wheels that hold the belts turn very slowly. There seems to be not enough power going to these wheels and the lever seems loose as well.
Any suggestions?
Jim Handke
07-17-2003 10:01:16
 Re: Case 444 Mower drive in reply to John, 07-17-2003 07:18:29
The clutch needs adjusting. The owners manual tells how, if you have one.
red
07-28-2003 20:20:03
 Re: Re: Case 444 Mower drive in reply to Jim Handke, 07-17-2003 10:01:16
im trying to find the year model of a case 444 i just got the serial number is 9634807 i cant seem to find it anywhere but this is my first tractor and the first time on this site
steve swanson
07-23-2003 18:16:31
The steering on right turns is jumping teeth. Is there a way to adjust the marriage of gears? I don't have any manuals for repairs or parts.
John
07-17-2003 15:26:50
I have a manual, but I see nowhere in it to adjust the clutch. Can you tell me where that adjustment is?
Jim Handke
07-17-2003 19:29:48
 Re: Re: Re: Case 444 Mower drive in reply to John, 07-17-2003 15:26:50
My manual covers the 446 & 448. Page 58 in my manual covers the adjustments. The adjusting nut is between the plastic fan and the over center clutch. You loosen the locknut(it holds the fan on the shaft)and tighten the adjusting nut. It calls for a 1 3/4" wrench, but I use a large slipjoint pliers. A firm push is required to engage a properly adjusted clutch. Sometimes when you tighten the locknut, the clutch tightens up. You may have to play with it for awhile before you get it right. I think it took me four times the last time I had to do mine.
John Saeli
07-18-2003 07:34:31
 Re: Re: Re: Re: Case 444 Mower drive in reply to Jim Handke, 07-17-2003 19:29:48
Hey Jim: John might have the older 444 with no adjusting nut. In that case shims must be added after disassembly.
Jim Handke
07-18-2003 09:37:50
 Re: Re: Re: Re: Re: Case 444 Mower drive in reply to John Saeli, 07-18-2003 07:34:31
My 448 is the only case mower I've ever been around. I didn't know the smaller one would be different. Thanks for the info.
Jim
John Saeli
07-18-2003 11:46:46
 Re: Re: Re: Re: Re: Re: Case 444 Mower drive in reply to Jim Handke, 07-18-2003 09:37:50
Hey Jim,; I think the clutches were the same on all models, except that the newer ones adjusted with that big nut.
John
07-18-2003 22:00:42
 Re: Re: Re: Re: Re: Re: Re: Case 444 Mower drive in reply to John Saeli, 07-18-2003 11:46:46
Ok, I am confused now....I tried dissasembling some of the 444 tonight, but couldn't tighten the center bolt on the fan...any other suggestions how to get my mower blades turning?
Jim Handke
07-20-2003 07:57:03
 Re: Re: Re: Re: Re: Re: Re: Re: Case 444 Mower dri in reply to John, 07-18-2003 22:00:42
I'm afraid I can't help on that model, but let me talk to my brother. He worked for a Case dealer for a number of years.
