Sickle Bar Mowers for DCs
Paul f
07-16-2003 06:44:59
I would like to get a sickle bar mower for my DC3 (Live PTO, Eagle hitch). I posted a want ad for a Case mower but had no replies. I was wondering if any of you are using non-Case mowers. The few three point hitch mowers I have looked at would have a really steep angle on the PTO shaft given the height of the PTO on a DC.
dave
07-20-2003 11:28:17
 Re: Sickle Bar Mowers for DCs in reply to Paul f, 07-16-2003 06:44:59
Did you buy that E-7? if not I am interested, I have a VAC 14 and a 530 and would like an E-7. If I would find an E-7 or E-10 I have a T-10 to sell (pull type)
C. Amick
07-17-2003 14:25:31
I have a 5.5 ft. Vicon disc mower on my SC. It has the old lifting bail which I converted to a 3 point hitch. I don't know how well the mower would work with an eagle hitch.
JW
07-16-2003 20:19:12
I have an E-7 Case mower that is for a SC or DC with eagle hitch. Has always been on our SC. E-mail if interested.
Paul f
07-17-2003 05:37:15
 Re: Re: Sickle Bar Mowers for DCs in reply to JW, 07-16-2003 20:19:12
JW I can't seem to email you. I am interested...please email me at [email protected]
Thankyou
Kennyp
07-16-2003 10:42:20
Colorado was home to a bunch of JD #5 mowers. Friend bought 3 junkers at auction this spring. Used parts from one . Sold one (with 3 point) for 200 to get his money back. Has the other on his SC. No problem with PTO. I think he bolted two bars along side the drawbar frame to extend it back to the JD's big flat hitch bar, which is a break-away. I think the only problem he had was looking for a little longer square shaft for thr PTO. Course Case would be nicer.
Jim Handke
07-16-2003 08:50:00
We had the same problem when we mowed with our SC's. We were using a couple of John Deere, a #9 was the newest of the two. Dad mounted a shaft right above the drawbar area, put a 540 shaft on the end, and ran a rollerchain from the shaft up to a sprocket on the pto shaft. We never had u-joint problems after that. These mowers were not three point mowers. They attached to the tractor on two shafts, one on each side of the drawbar assembly. They would pivot on the shafts, and had a tail wheel on the rear of the mower.
