Is my 49 LA + or
ground?
Steve-IA
07-15-2003 06:18:42
I've had my LA hooked up negative ground for 2 years & the people who just rebuilt my generator said the regulator is set up for Positive & want to know how I want it wired.
Anybody know for sure?
Any input would be appreciated.
Thanks,
Steve
RandyD
07-15-2003 15:29:07
 Re: Is my 49 LA + or - ground? in reply to Steve-IA, 07-15-2003 06:18:42
I think you should get you a manual. So far we have found SCs are neg ground and VAC pos ground.
Go figure.
Will
07-15-2003 10:06:37
LA should be - ground.
caseboy
07-15-2003 09:39:03
49 la would have come stock as 6 volt pos grd. most 6 volt is pos grd. most 12 volt is neg grd. if yours is still 6 volt, i would stick with the stock pos grnd
Steve-IA
07-16-2003 06:17:49
 Re: Re: Is my 49 LA + or - ground? in reply to caseboy, 07-15-2003 09:39:03
Caseboy,
It's still 6 volt. I'll have them put a Pos ground Regulator on it again. I did not know starters would work correctly both + & -. Learn something new every day. Hopefully I'll remember to reverse my battery:).
Thanks very much for the info!
Steve
