So is a 570 worth repairing/restoring?
Ryan
07-14-2003 20:16:41
My grandfather had a 570 that he farmed with until recently. (this is where I also got the VAC, although it had sat for 20 years) It appears that gramps had only water in the block because we were told it has a crack in it. I know that the 570 is rare and all but is this tractor still going to be worth anything as far as collectors are concerned if the block is rewelded? If it isn't I am going to rob some parts to put on the 530 and send the rest down the road.
Jeff From WI.
07-18-2003 07:48:42
 Re: So is a 570 worth repairing/restoring? in reply to Ryan, 07-14-2003 20:16:41
Ryan, if you want to sell it i'm interested. i'd fix her and Farm with her. please e-mail me. Thank You Jeff From WI.
J.R.
07-16-2003 19:25:52
No, they made 530 gas or diesel and the 570 replaced it in 1970 and was also offered in gas or diesel. I take it yours is gas. Is it otherwise complete? JR
Ryan
07-17-2003 05:32:39
 Re: Re: So is a 570 worth repairing/restoring? in reply to J.R., 07-16-2003 19:25:52
Yeah, the 570 is a gas and the 530 a diesel. I just assumed they were all that way. What are the differences between the 530 and 570 platforms? And yes the tractor is complete.
J.R.
07-17-2003 18:18:34
 Re: Re: Re: So is a 570 worth repairing/restoring? in reply to Ryan, 07-17-2003 05:32:39
There are very little different. The block of both gas and diesel are different. There is no eagle to be found anywhere on the 70 series. The last of the 570's had alternators instead of generators. Other than that, the tractors were about identical. JR
Dennis/Ohio
07-19-2003 03:41:27
 Re: Re: Re: Re: So is a 570 worth repairing/restor in reply to J.R., 07-17-2003 18:18:34
Hi Jr, Tell me the difference in gas engine blocks. I assumed 570 had the 159 same as a late model 530? Will complete engine swap? Thanks, Dennis.....
Keith A NNY
07-16-2003 00:48:31
Keep it in the family. Fix it up and enjoy.
J.R.
07-15-2003 19:28:23
I doubt that the 570 will make collector's status, but they are very useable tractors. Is yours gas or diesel? I own two 530's that are aching for some parts that are missing. I read the previous posts and will sell brake parts and others if you want to sell in one piece. Where are you located? How much for the complete tractor and what are you wanting to take off it? Blocks for the 570 are difficult to find and require alot of labor to change. Take what you need and send the rest down the line. JR
Ryan
07-16-2003 14:37:03
 Re: Re: So is a 570 worth repairing/restoring? in reply to J.R., 07-15-2003 19:28:23
Correct me if I am wrong but doesn't a 570 have to be a gas? I was under the assumption that 530 is diesel, 570 is gas.
John H-WI
07-15-2003 06:04:58
Not that many 570's around. Its your call, if mine I'd fix it up!
Dennis/Ohio
07-15-2003 03:32:09
Hi Ryan, If you part it out, my 530 backhoe is early version and doesn't have the band type brakes. The 570 would probably have everything I need to convert to better brakes. Thanks, Dennis..... .
