Hey Randy, The SC is looking great! I've often wondered the same thing about the tools that were supplied in the tool kit. I'd like to collect the missing tools for my '49 as well. Page 150 of the parts catalog has an illustration and description of the various tools- but I don't think that all of them would have been in the standard tool kit. I'll try to get it scanned next week. If I had to guess which items were included in the factory too kit- here's what I would think... #06019A Handle- Spark Plug Wrench #01982AB Wrench- for 01246AB rear axle shaft nut (this looks like the same open end, closed end wrench that takes the grease caps off the front wheels of a CC or DC tractor)
#6302AB Wrench- spark plug #06304AB Wrench- socket, for rear wheel hub and rim clamp nuts #06369AB Bar, adjusting, for clutch (this would have later changed to #09342AB which is the Z-shaped bar for the late model tractors with live PTO and different clutch types.) #06785AB Tool, tire #07558AB Gun, grease, 5 oz. capacity. Lincoln No. 5950 or 5958. #07562AB Wrench, 10" Crescent #07565AB Wrench, double-end, 3/8" x 1/2" No. 723A #07566AB Wrench, double-end, 7/16" x 9/16" No. 725A #07567AB Wrench, double-end, 5/8" x 3/4" No. 729A #07568AB Wrench, double-end, 13/16" x 7/8" No. 731B. #07569AB Wrench, double-end, 15/16" x 1-1/16" No. 34A #07570AB Wrench, double-end, 1" x 1-1/8" No. 735. #07628AB Guage for setting spiral bevel pinion #139AA Pins, set of spreader- to spread engine and transmission. Consists of (2) #02064AB pins and (8) 3/16" x 1-1/4" cotter pins. Everything else in the tool list seems like specialty items that would probably be purchased as needed. Maybe the spreader pins and the gear guage fall into that category... maybe somebody with dealer experience can tell us for sure what was in an original kit.
I do know this- my 1941 Parts Catalog for the early model SC's has a very different set of tools. They had three wrenches, a spark plug wrench and handle, a set of 4 spark plugs! the clutch adjusting bar, a lug wrench, the Lincoln grease gun and an oil can. Keep me posted on what you learn. -Schotte
