Positive Vs. Negative ground?
RandyD
07-13-2003 05:16:00
Anybody know why Case would design the SC with a negative ground and the VAC, per the recent discussion, with a positive ground?
I find this a bit odd.
Mike Schotte
07-13-2003 06:54:22
 Re: Positive Vs. Negative ground? in reply to RandyD, 07-13-2003 05:16:00
I always heard that the Racine built tractors had a negative ground (like the SC), but the Rock Island built tractors had a positive ground (like the VAC.)
-Schotte
Jim Handke
07-13-2003 08:26:48
 Re: Re: Positive Vs. Negative ground? in reply to Mike Schotte, 07-13-2003 06:54:22
Has anyone ever figured out why there is a positive ground configuration? What is supposed to be better? Dad had a JD 70 that I ran as a teenager, and it had positive ground. Just wondering.
Mike from Canada
07-13-2003 09:30:41
 Re: Re: Re: Positive Vs. Negative ground? in reply to Jim Handke, 07-13-2003 08:26:48
positive ground, in theory, is better from an electrical standpoint. electrons flow from neg. to pos. and not the other way around as so commomly understood. therefore resistance to flow is decreased and makes for better cranking.
so if the entire tractor is grounded positive, it should be no trouble for accessories to move electrons from the battery.
its easier to pour a bottle of water into a lake than it is to pour a lake into a bottle.
hope this helps!
mike
Kenny
07-15-2003 07:05:55
 Re: Re: Re: Re: Positive Vs. Negative ground? in reply to Mike from Canada, 07-13-2003 09:30:41
Mike, being an electronic person, I wouldn't touch that explaination with a 10 foot pole. I will just say that Ford though there was some reason for it on all their early models. My first car was a 36 ford. The polarity of the spark at the plugs was such that they caused "blimps" in TV sets. GM cars did not, since the TV tube used negative vidieo signal to the CRT. I am perty sure that the coil should to be matched to the polarity for best, but I could be in question on that.
Mike from Canada
07-15-2003 09:20:58
 Re: Re: Re: Re: Re: Positive Vs. Negative ground? in reply to Kenny, 07-15-2003 07:05:55
from what i was taught, RF interference for TV sets and radios was caused by ignition systems using copper wires which had no capacitive value and just carried electrical current from the coil to the plug. the snap of a points set or a magneto could be transmitted electomagnetically to antennas within a close range causing static or "drop out" in audio/visual signals. now a days, ignition systems use high-voltage coils, electonic ignition (no points, only magnetic pick-ups) so theres no moving parts, and carbon core wires that are semi-conductors and act as a capacitor to deliver a stronger spark to the plug.
everywhere a spark has to jump, it has the potential to create RF interference. some engines eliminated the cap and rotor in favour of "direct" or "distributorless" ignition for efficiency and even fewer moving parts. and as a by-product, created less RF interference. some manufacturers installed "filters", that were nothing more than variable frequency capacitors, to the electrical systems to cut down on RF interference.
im not certain why Ford decided on positive ground and GM chose negative ground. all i know is your explanation may have some merrit based on output reasons but its nothing that cant be cured nowadays.
hope this helps
mike
Kennyp
07-15-2003 15:27:53
 Re: Re: Re: Re: Re: Re: Positive Vs. Negative grou in reply to Mike from Canada, 07-15-2003 09:20:58
I just feel like being a little pickey today. You are pretty much right. A spark will generate radiation of all most every frequency..from light up to, if voltage is high enough, X rays. Something around 15000 volts for Xrays. Begining to get there with TVs. Variable frequency capacitor--sorry. Variable capacitors..yes. A filter can be a resistor (in the wire) and a capacitor to shunt the voltage spike out. Called a RC filter. Or a LC filter which is and inductor (a coil of conductor) and capacitor. The value of inductor and the value of capacitor determine the frequency and make it a tuned circuit. Filters can be either "pass through, or pass to ground. Very over simplified. Wires close to a frame or in a conduit can make a capacitor. See, your right about the cored wires. Tuned circuits are a fun thing, kind of like a pendilum. The induntance of a spark coil and the capacitor across the points are actually a tuned circuit. This gives a much higher voltage out than the straight turns ratio of the coil/transformer. Thats why a spark plug fires on the opening of the points and not the closing. One look at a spark plug voltage on a test ocilascope realy shows this. None of this explains why Ford used one way and Gm the other. Doubt if we will ever know for sure. Have a good day...Kenny
Mike from Canada
07-16-2003 00:21:52
 Re: Re: Re: Re: Re: Re: Re: Positive Vs. Negative in reply to Kennyp, 07-15-2003 15:27:53
well, thanks for the detailed info. its a lot for me to remember but thank goodness antique tractors are simpler. lol.
my background is more auto electric than electronic. the courses during my apprenticeship were never that detailed. maybe if i were to get into more car stereo equipment i would know so much.
once again, thanks
mike
p.s. about the Ford/GM thing, you brought it up. lol.
cw
07-13-2003 10:29:13
thanks mike,i have a '61 fordson super major that is a positive ground,i was wandering why it had reverse polarity. cw
