Tool kit
mike
07-12-2003 16:26:24
I bought a case tool kit,and wanted to know if i could get some help identifing the tools.
The tools came in a large wooded crate with hinges,which allowed each side to open equally.Inside was a guage with a 30" 1/2" od rubber hose with brass 1/4 fitting . the guage goes to 300? .There are three tools inside about eight inches long.The the box has the case eagle on the goble in front. It has diesel tool and---- Co. on the front. Thanks
Klyde
07-13-2003 19:28:54
 Re: tool kit in reply to mike, 07-12-2003 16:26:24
Mike, Sounds like you got part of the diesel kit. It originally contained a compression tester and a adapter to go in in place of an injector. An injector seat reamer, power cell puller and power cell seat reamer. Lapping plate and mutton tallow to reface the power cell halfs and to reface injector bodies when installing new tips. A crowfoot bar to "pull" the injectors with and a precision tach. also a bunch of small scrapers and reamers to clean injector tips. I think I have an original Sheet that goes with it That I could scan if you want it. Klyde
mike
07-14-2003 04:41:39
 Re: Re: tool kit in reply to Klyde, 07-13-2003 19:28:54
That would be great if you could scan that list for me.The kit is missing some parts, i have two reamers,compression tester, and threaded rod with a adjusting nut.
Thanks for the help!! Mike
Mike Schotte
07-13-2003 06:56:46
I bought a book listing Case factory service tools for sale to dealers from Case awhile back off of Ebay... and it listed lots of those kind of kits.
If you have a picture or any numbers off of the kit, maybe I can help you identify it.
-Schotte
(wondering where he put that book...)
Joe (Wa)
07-12-2003 19:01:33
Probably compression tester.
