VAC Eagle Hitch
Holloway Farms
04-27-1999 17:40:43
I just bought a '51 VAC and the arms on the Eagle hitch only go down with a lot of weight on them. Does anyone know what whould cause this? The arms go up quickly and smoothly just don't want to come down.
toolbox
04-29-1999 20:37:31
 Re: VAC Eagle Hitch in reply to Holloway Farms, 04-27-1999 17:40:43
The arms on mine come down easily if I put a foot on one. If there's an implement on, it lowers easily also. The only thing I can think of right now is to check the drain line, the return line, and breather cap on the return line. Make sure that none of these are obstructed.
Frank R
04-28-1999 06:17:27
Mine has done the same thing since I bought it about a year ago. I'm planning on changing fluid and filter to see if that cures it. So, you're not alone in wondering this. Does yours make strange noises if you happen to try to lift too much with it?? I've got a boom for mine and I have to watch how much I try to pick up with it.
Craig L.
04-28-1999 08:46:56
 Re: Re: VAC Eagle Hitch in reply to Frank R, 04-28-1999 06:17:27
you can pull the lift lever and plate off, and behind that there is a rocker type valve with adjustments alot like the rockers in the valve train in the engine. you can adjust that to open up the "down"side of the lift system. This takes about 30 min to do.
Frank R
04-29-1999 08:43:43
 Re: Re: Re: VAC Eagle Hitch in reply to Craig L., 04-28-1999 08:46:56
Is this covered in the shop manual as far as how much to adjust, etc???? I've got a copy of the original shop manual as well as a copy of the original owner's manual.
Craaig L.
05-02-1999 16:33:26
 Re: Re: Re: Re: VAC Eagle Hitch in reply to Frank R, 04-29-1999 08:43:43
well basically you just adjust the free travel out of the rocker on it. no set amount that i know of to adjust, just to where it satisfies you is the best that i can tell you
