you made a good choice for a restoration. VACs are easy to fix and most parts are still readily available @ the dealer. to answer your questions: 1) you may not need to convert your tractor to 12V. see if you can get your hands on an 8V battery. it'll give you all the crank you need w/o having to change lights, ignition coil, points, condenser, etc. 2) the sleeves are fitted into the block w/ o-rings. you may have to tap them out from the bottom. ive got the row crop front end on mine so i didnt have to worry about removing it. 3) someone is always selling carb kits on e-bay. just search for "case tractor" and you'll see it somewhere. i got mine @ the dealer, it wasn't too expensive (or cheap for that matter). 4) body panels and other parts are available on e-bay as well. theres currently a pair of fenders for sale. same search applies. 5) well, it depends. some say positive ground, some say negative ground, some say it depends on which assembly plant it was made at. i say: if it has mag ignition its positive ground, if it has points ignition its negative ground and ive been told thats not true either. if you want to find out quick, test your starter. see w/ direction it turns when you hook it up one way or the other. if the drive gear kicks out on contact, thats the polarity of your ignition. (i hope... w/ my luck its uni-directional and will only turn one way regardless of polarity). 6) it depends. usually, yes they were painted all one colour - flambeau red (orange) w/ the exception of the rims which were galvanized. (just paint them tremclad aluminum... its close enuff) towards the end of production (in 55) there may have been a few tractors painted the two-tone flambeau red/desert sunset (beige). 7) i have 3 books that i refer to as the holy trinity. my CaseIH parts catalogue for VA tractors, my CaseIH service manual for VA tractors and engines, and Peter Letourneau's Case Tractor Buyer's Guide (2nd edition). the firs two you can get at the dealer, the third one you can buy from this site, indigo, amazon.com etc. i reccomend finding a VA parts catalogue on e-bay. folks say the older the publication the better. apparently the newer they got, the less they contained and the less detailed the illustrations became. i can believe it. mine is about 15 years old and compaired to an original publication, the pictures may as well be drawn by a 1st grader. we're all here to help. feel free to post anytime. hope this helps, good luck! mike
