Loose crank pulley on SC
Terry
07-11-2003 10:37:46
I have an SC that I recently purchased with what I was told was an engine knock but runs. I didn't start the tractor, I bought it and took it home. It looks to me that the front crank pulley is loose. How is this supposed to be fastened to the crank? I am unfamiliar with A/C and haven't looked into repairing yet. Thanks, Terry
Klyde
07-11-2003 23:24:51
 Re: Loose crank pulley on SC in reply to Terry, 07-11-2003 10:37:46
About 20 years ago I overhauled a SC that the owner insisted had a bad rod. Rods were fine, crank and pulley were shot on the front. Owner had replaced tapered pin through pulley with a roll pin, was'nt tight enuf and pulley and crank suffered because of it. Remember putting in a used crank and bearing cause it was cheaper than fixing the crank and pulley, probobly not so today. If its just chucking on the pin run a tapered reamer through the hole and pound in a new pin.(it's gotta be tight) Check the crank for double taper under the pulley, if its stright and the pulley don't wobble put some bearing mount loctite on the shaft and pound a new taper pin in it. If it wobbles or is real loose might as well pull it and get it built up and turned down. $ouch$ Sorry this is sooo long.
Slowpoke
07-12-2003 21:01:33
 Re: Re: Loose crank pulley on SC in reply to Klyde, 07-11-2003 23:24:51
I've worked with smaller taper pins that were threaded on the small end for a 6/32 nylon insert nut. I don't know if larger sizes are available.
C. Amick
07-11-2003 13:55:37
The pulley has a pin that goes all the way through the pulley collar and the crankshaft. This pin must fit tight. It should require a punch to remove it. Sounds like the pin may be falling out and/or the hole is worn.
Mike from Canada
07-11-2003 13:05:46
hmm...
usually its one bolt or nut that holds it in the centre but it sounds like that may not be the problem.
i think you may have a broken crankshaft
yikes
mike
Jim from MI
07-31-2003 19:54:40
 Re: Re: Loose crank pulley on SC in reply to Mike from Canada, 07-11-2003 13:05:46
I have a 1954 SC that had a loose pulley. This is what I did. I removed the pulley, cleaned the shaft and the inside of pulley. I then applied JB weld to all the surfaces and reassembled. I then wedged toothpicks around the shaft and pulley to align it straight. To check the alignment I cranked engine over with starter and watched the pulley,then I readjusted toothpicks as needed. Then let it set for 24 hours. Installed belt and its been 2 years and its still solid. Jim
Mike from Canada
08-01-2003 08:09:48
 Re: Re: Re: Loose crank pulley on SC in reply to Jim from MI, 07-31-2003 19:54:40
WOW... now thats an endorsement JB weld should hear about: "i used JB weld on the crankshaft of my old Case tractor and its still holding after 2 years!"
you cant knock that stuff!
mike
