Rebuild Kit for 401 diesel
Robert
07-10-2003 13:00:38
Can anyone give me a resource for a rebuild kit for the 401 diesel engine?
Dale in Tx.
07-11-2003 16:27:52
 Re: Rebuild Kit for 401 diesel in reply to Robert, 07-10-2003 13:00:38
Robert, What you have is A 400 model in A diesel which is 401 in diesel,411 in gasoline, it has 4in pistons if it's still standard,251 cid,the 401 super that came in 1957 had 41/8 pistons, made quite a diff..The kits should be aviable from case-IH,or m&w,kit for pump also, Good luck Dale In Tx.
robert
07-11-2003 21:08:22
 Re: Re: Rebuild Kit for 401 diesel in reply to Dale in Tx., 07-11-2003 16:27:52
Ok, that is what I need to start looking for an engine rebuild kit, the parts counters require a cu in displacement to lookup. Thank you very much Dale!
george md
07-10-2003 17:29:05
Robert ,
Which 401 do you have , A401 or 401 BD ?
I have done one of each recently , and I can
supply parts .
george
Robert
07-11-2003 12:34:57
 Re: Re: Rebuild Kit for 401 diesel in reply to george md, 07-10-2003 17:29:05
I have no idea as to what engine is in this tractor George. The model number is 401 and the id is 8061737. This may be a series 400 and a 1955 tractor according to serial number?
bob
07-10-2003 14:56:12
Try this number Diesel power and machine in indiana 1-800-825-7711 ask for tractor parts. Same stuff you get from tisco. but cheaper, were do you think they get there stuff.
I would with them alot and real good to deal with
Aaron
07-10-2003 14:14:48
For a 930 or a 970? You can get rebuild kits from your local Tisco dealer.
Robert
07-10-2003 15:59:44
 Re: Re: Rebuild Kit for 401 diesel in reply to Aaron, 07-10-2003 14:14:48
I called our local Tisco dealer and they have not heard of a 401 diesel engine. Not listed in the books.
bob
07-10-2003 19:51:40
 Re: Re: Re: Rebuild Kit for 401 diesel in reply to Robert, 07-10-2003 15:59:44
DO you have a 4 cylinder or 6 cylinder engine. A 401 engine was used in the 930 tractors. ANd the was a model of tractor that was a 401. In my earlier post give them a call they are pretty sharp if they can't help you email me i can get some more info for you.
Robert
07-11-2003 12:41:43
 Re: Re: Re: Re: Rebuild Kit for 401 diesel in reply to bob, 07-10-2003 19:51:40
The model number on the dash is a 401 with serial number 8061737, the engine is a 4 cyl. Hope this identifies what I have so I can buy a engine rebuild kit and oil pump.
