The day you dread
Keith Alexander
07-10-2003 03:51:20
I have been in the process of redoing my 311b. Everything was going so good... put everything back together last item was to put the water in. I am finding two small water leaks @ the head (small little drops like weeping) from the area between # 3 & 4 on the manifold side. Both head and block were shaved by a reputable machine shop and I checked them with a straight edge and feeler blades. It appears that the head gasket didn't compress as much in this area as the rest. Followed torque down pattern to the correct torque. Using a victor head gasket... any other manufacturers I could try? Any other suggestions would be welcome. To come this far and hit a snag is a real downer
Terrance
07-12-2003 13:54:49
 Re: The day you dread in reply to Keith Alexander NNY, 07-10-2003 03:51:20
Try retorquing the engine hot if that doesnt work check to make sure that the sleeves are not setting too high causing the water passages not to seal,sometimes shops forget to take the counter bores for the sleves into account when milling a block deck.If there is any rust in the block or heads after having them done at a machine shop I would question their practices as most decent shops still hot tank blocks and heads before working on them.Oil and or water passages could be plugged and ruin a good machining job as well as a good reputation. Caustic soda is not much of an enviromental hazard at all probably safer than most household cleaners if handled properly.To attempt to assemble an engine that hasnt been cleaned preoperly is just plain bad mechanical practice.If any rust is the cause of your sealing problem you should take the engine apart and clean it properly before you ruin it,and waste a lot of money.
Thank You Terrance
Mike from Canada
07-11-2003 00:54:09
did you use thread sealer on the bolts?
some of them thread into an open water jacket like on my VAC and if they arent sealed the water will creep through the bolt holes and out to where ever it can.
just a thought
mike
J.R.
07-10-2003 19:05:56
When you retorque the head, do it only cold. If it doesn't stop after running at thermostat temp for an hour, I agree with the idea that rust deposited on the gasket from the stud holes as you dropped the head on. Remove it, clean the surfaces and holes, and install a new gasket. JR
george md
07-10-2003 14:02:53
Keith,
Being that you had the block resurfaced, did the shop recut the counterbores to spec ?
george
rayinny
07-10-2003 13:32:28
Rust and dirt in the bottom of the bolt holes could be the problem, also cleaning the threads might help.
Kennyp
07-10-2003 09:23:14
I second the "copper coat" for sealer. You did run a tap on all thread holes if studs and die on all bolts if nuts, didn't you? a bottomed out bolt can fool you on tightness.
jerry
07-10-2003 09:15:07
Keith, Retorque the head after you run the engine , Loosen one head bolt at a time and torque to specs. this should spot your leaks .then start it back up and run the engine.
C. Amick
07-10-2003 09:11:11
Retorquing the head after the has came up to running temperature is the first thing to try. If you have to remove the head and buy a new gasket, buy some of the copper spray sealer at an auto parts store to go on the gasket before you put the head back on.
Bruce Nelson
07-10-2003 07:49:51
Keith, before you do anything, start the tractor and run it till the engine temp gets to 180 degrees. Retorque the head bolts just like you torqued them when you put the head on. Most of these gaskets are coated with a sealer that takes heat to "melt" into place. I have assembled hundreds of tractors from this era and never worried about early coolant seepage. The above plan always cured it.
Bruce
RobertTX
07-10-2003 06:05:36
I have had problems with heads dropping rust onto the gasket as I install them. The machine shops don't use the hot tanks any more (environmental?), and the heads can have some loose rust in the jackets. One thing for sure - you are going to have to pull the head, and when you do you should be able to see what the problem is. Don't worry about it, it's not that big a deal.
bob
07-10-2003 05:27:31
Did you use a sealer on the gasket?
