Ford 4500/case 580 need a mechanic in northern ill
Jason
07-09-2003 11:54:46
Hello-
I own a Ford 4500 and a 1970-ish Case 580CK which have been in storage for several years. I'm looking for someone, for hire, who can work on the tractors. The Ford needs some general maintenance (it won't start after being winterized) and the Case's transmission will not engage to go forward (but will go backwards fine). Some small other fixes are needed as well, but nothing major. Any help or direction pointing would be greatly appreciated.
Thanks.
Gary J
07-26-2003 17:55:25
 Re: ford 4500/case 580 need a mechanic in northern in reply to Jason, 07-09-2003 11:54:46
I too have a 580CK. I had to change the Shuttleshift twice to get the water out that collects from condesation when these things set. My CK had two drains on the shuttelshift and both need to be drained. I also started the engine for a second or two a couple of to get the contaminated fuild out of the torque converter while both plugs were out. Then before refilling the shuttleshift I replaced the filter which is in front of the raditor. After doing this it ran and operated fine. Something you could try yourself.
Good Luck, Gary
