LA Case with Detroit Diesel
David Manring
07-08-2003 19:53:40
Anyone out there own one? Have a pic of one?
DON L
07-10-2003 15:23:21
 Re: LA Case with Detroit Diesel in reply to David Manring, 07-08-2003 19:53:40
I have one with a 4-71 and a 3-71 in a LA. sorry no pics till I get time..
Don L.
Bruce Nelson
07-09-2003 10:05:59
Dave, Don L has a few of these. Call him at 507-433-0073 You would have your best chance to reach him in the AM. Bruce
Mike from Canada
07-09-2003 07:57:18
i know that Case experimented w/ diesel in the early-mid 50's using the LA as a template. they tried the Hesselman design in the rare LAH but it wasnt a true diesel. they adapted the engine other ways but even though the engine appeared big n' beefy, it couldnt handle the heat and compession, and often grenaded during early tests. the early models w/ a successful working 6 cyl were called LADs before given the designation "model 500".
ive seen a JD w/ a 2 stroke GM diesel but not a Case w/ a detroit diesel.
hope you find what your looking for
mike
Tom F
07-09-2003 16:53:31
 Re: Re: LA Case with Detroit Diesel in reply to Mike from Canada, 07-09-2003 07:57:18
Mike
Just curious--what is a Hesselman design engine?
Never heard of it.
Thanks
Tom F
Mike from Canada
07-10-2003 03:46:05
 Re: Re: Re: LA Case with Detroit Diesel in reply to Tom F, 07-09-2003 16:53:31
im not exactly sure either. im just reading the exerpt from my Case Tractors Buyers Guide.
"In 1942, Case introduced the standard LAH and industrial LAIH which featured the Case engine modified to accommodate the use of diesel fuels. The design, known as the Hesselman engine, was not a true diesel. Rather, it was a fuel-injected, spark-ignited engine. By 1949, Case had built approximately 450 tractors with the Hesselman engine."
now, fuel injected i can understand. but spark ignited? HUH? those injector nozzles must be microscopic to get the proper ppm for diesel to burn w/ a spark plug.
anyway, hope this helps
mike
INCase
07-09-2003 13:26:11
Oliver (white) used the GM 2 stroke (screaming Jimmy's) quite a bit in the early/mid 60's
Jim Handke
07-09-2003 16:58:26
 Re: Re: Re: LA Case with Detroit Diesel in reply to INCase, 07-09-2003 13:26:11
A guy about 15 miles from here had a GM equiped Oliver. Really gutless. Had to run a gear lower to keep the rpm's up.
jd730
07-09-2003 20:49:49
 Re: Re: Re: Re: LA Case with Detroit Diesel in reply to Jim Handke, 07-09-2003 16:58:26
I used to have a LA with a 3/71 Detroit, we have a LA with a 4/71 and a LAI with a 3/71 in our club. I know of several LAs with Detroits in them. Detroit developed a kit for the conversion in the 50s. I have copies of the original conversion instruction from Detroit. They also made kits for a D Case,M and W6 IH, G moline and early 99 Olivers. There were many conversions done in wheat country. Later Bill
david manring
07-10-2003 02:46:27
 Re: Re: Re: Re: Re: LA Case with Detroit Diesel in reply to jd730, 07-09-2003 20:49:49
Bill, yea i'm in Sunray Texas i would like to see a pic of the adapter they used to bolt it togeather. Am i in wheat country?
jd730
07-10-2003 21:30:29
 Re: Re: Re: Re: Re: Re: LA Case with Detroit Diese in reply to david manring, 07-10-2003 02:46:27
David Send me a email and I will see what I can do to send you some info. Later Bill
