SC Magneto Question
Paul f
07-08-2003 06:07:54
A friend has an SC. She runs on two cylinders 1&4, there is no spark in 2&3 (Checked at plug and at the mag cap). Cleaned rotor and contact points in cap to no avail. What should we look for next. (I am mag challenged, my DC had been converted to distributor)
Thanks
Paul f
Paul f
07-10-2003 06:14:47
 Re: SC Magneto Question in reply to Paul f, 07-08-2003 06:07:54
Thank you all we will check these suggestions and let you know what we find
Klyde
07-08-2003 09:30:25
Another possibility is that the point lobe is worn on one side so that the points are not opening the same. What you said about 1&4 and 2&3 would make me want to check that lobe! (1&4 are fired on the same side of the lobe and 2&3 are fired on the other) The point sets used to come with a new lobe just for that reason. Just a thought.
John Saeli
07-08-2003 10:34:26
 Re: Re: SC Magneto Question in reply to Klyde , 07-08-2003 09:30:25
Hey Klyde; Never knew that. Thanks, just learned something. BTW, I have NOS coils for the 41 mag.
caseman-d
07-08-2003 20:48:12
 Re: Re: Re: SC Magneto Question in reply to John Saeli, 07-08-2003 10:34:26
What you asking for a coil???
caseman-d
John Saeli
07-09-2003 11:30:59
 Re: Re: Re: Re: SC Magneto Question in reply to caseman-d, 07-08-2003 20:48:12
Hey caseman-d; I get $60.00 for the NOS coils. Add $5.00 for postage on that.
caseman-d
07-11-2003 18:05:08
 Re: Re: Re: Re: Re: SC Magneto Question in reply to John Saeli, 07-09-2003 11:30:59
John,
Thanks for the info. I just picked up a Case DC for 75.00 and it has a mag that works and another parts mag I'm not sure if the second one is all there or not.Will keep you in mind.
later
Tom
RobertTX
07-08-2003 06:38:50
About the only thing left is the contacts in the cap and the springs under them that also serve as the connection from the contact to the female plug the wire goes into. It is possible for there to be corrosion that is causing the problem. Gently pull the spring loaded contacts up and look under them, spray cleaner or WD 40 in there and check for continuity.
One other possibility is that the wires are not seating far enough into the cap when you plug them in. They can be hard to get seated all the way, there can also be corrosion in that area.
