Case VAC Parts- Where Can I Buy Them?
Ron
07-08-2003 05:11:18
Hello: I'am looking for some of those rubber boots that go on the the geer shift lever on the Case VAC tractor. I checked at our local T.S.C. store but those rubber boots are too small they wont fit the top of the transmission housing.
Thanks
Ron
good old boy
07-12-2003 11:24:24
 Re: Case VAC Parts- Where Can I Buy Them? in reply to Ron, 07-08-2003 05:11:18
i have a 49 vac and there aint a bolt on it i havent touched . the shift boot yoy bought i too need one but my case dealer in my town every body quit . every body that work's there cam from new holland, ford, so if you have a part # for the boot you put on you tractor i sure could use it [email protected]
Ron
07-09-2003 04:49:26
I asked you guys about getting a boot for geer shift lever well I was gona order it from Don for $16.00 pluss $5.00 S&H but then I called our local Case dealer and he said I have one in stock for the Case VAC so I stoped on the way home last night and picked it up and it fits like a glove. My cost was $9.75 for the boot! Iam glad I called our Case dealer!!!
Thanks guys
Ron from Pa
Steve Staysko
07-10-2003 21:17:56
 Re: Re: Case VAC Parts- Where Can I Buy Them? in reply to Ron, 07-09-2003 04:49:26
The Case part number for the gear shift rubber boot is IH36898, Note that the I could also be a 1 the number isn't very legible.
Ron
07-08-2003 09:43:08
I FOUND THE BOOTS! Thanks to jal-SD . Call Don at 507-433-0073 he has them in stock they are $16.00 each with shipping cost of $5.00
Thanks
Ron in Pa.
Steve Staysko
07-08-2003 06:52:34
There still available at your local Case Dealer. I just bought one two months ago.
Mike Schotte
07-08-2003 08:40:31
 Re: Re: Case VAC Parts- Where Can I Buy Them? in reply to Steve Staysko, 07-08-2003 06:52:34
Hey Steve,
Long time no see on the boards. How's the project going?
-Schotte
Steve Staysko
07-09-2003 07:19:11
 Re: Re: Re: Case VAC Parts- Where Can I Buy Them? in reply to Mike Schotte, 07-08-2003 08:40:31
The Tractors is currently split in 3 pieces and I still can't see the light at the end of the tunnel. The big problem was that a previous owner cut the rear axles, he probably got tired of taking out fence posts. I've just sourced another set of axles of which I still need to install. I'II slowly plod along like a turtle and do the job right...
Georgia
07-08-2003 08:33:30
Does this Case dealer have an email address, or do you have the part # for the boots?
jal-SD
07-08-2003 06:44:48
Have you checked w/Don L? I got a boot for my '54 SC two weeks ago-he's probably got 'em for VAC's as well. Call 507.433.0073, AM best. (My $0.02 worth. jal-SD)
Arthur
07-08-2003 05:23:24
I could use one of those myself....Let me know if you find one, but more importantly, where you get one....Thanks
