Engine Removal, David Brown 900
Peter, U.K.
07-08-2003 01:52:16
I'm having a great deal of trouble removing the engine from a DB 900 with a dual clutch I'm restoring. The problem is that I can't get the PTO shaft back far enough to clear the clutch housing to then lift the engine out. Is there a way of doing this without splitting the tractor?
As you'll be able to tell, I'm new to David Brown, this is the first I've undertaken so any help would be most appreciated.
Peter, U.K.
07-08-2003 12:25:56
 Re: Engine Removal, David Brown 900 in reply to Peter, U.K., 07-08-2003 01:52:16
Problem solved. The PTO shaft was being held solidly in the clutch by rust. A little brute force solved the problem and the engine is now out.
JCmarleau
07-08-2003 05:58:06
all i can help you with is i have a parts manual for sale if this can help you. my e mail is [email protected]
