VAC descriptions
Georgia
07-07-2003 13:04:11
I see alot of case tractors on various websites. Some tractors are called VAC when they don't have the tricycle front end. Wouldn't the wide fronts be called just plain old VA? Or am I missing something?
Mike from Canada
07-08-2003 02:00:16
 Re: VAC descriptions in reply to Georgia, 07-07-2003 13:04:11
like Bill said, VACs came in many different styles. between 1942 and early 1951 VACs were interchangeable w/ front end set ups. it just depended on what you wanted to order.
the difference between a standard tread VAC and a VA is the profile of the tractor. VAs had a low ground clearance. it also had wider rear tires and 16" fronts. standard tread VACs may have had a higher ground clearance w/ narrow rear tires and 15" fronts.
hope this helps!
mike
Bill Hires
07-07-2003 15:34:16
The VA Standard tread was built from 1942-1953, the VAC Dual-tricycle row-crop 1942-1953,VAC-11 Single front wheel 1951-1953, VAC-12 Dual-tricycle row-crop 1951-1953, VAC-13 Adj. Wide-front row-crop 1951-1953 and VAC-14 Utility configuration 1953-1954.
Dave
07-09-2003 08:49:47
 Re: Re: VAC descriptions in reply to Bill Hires, 07-07-2003 15:34:16
Close, I have a VAC 14 that was built in 1954 and has the tricycle front end. There are several more like it in the Central Ohio region
Georgia
07-08-2003 08:30:11
Thanks
